Sisärenkaattoman paikkaus "kamelinpskalla".....
Hanski T
Re: Sisärenkaattoman paikkaus "kamelinpskalla".....
Viesti Kirjoittaja Hanski T »
maja2 kirjoitti: ↑Ti Marras 25, 2025 12:05 am Pikkasen hienompi paikkasysteemi, hinta ei paha.
https://www.youtube.com/shorts/2nFQSzwP ... ture=share
No nyt. Mut mitenkähän se tutti tarttuu sisäpintaan kun sitä ei reiän ympäriltä pääse raspaamaan... Epäilemättä se on kuitenkin parempi kuin perinteinen kamelinpaska (siihenkin joku vulkanointineste on hyvä lisuke).
SF 1098S
MTS V4S
JuhaL
Pyörä: CRF1000L DCT
Viesti Kirjoittaja JuhaL »
XL250R kirjoitti: ↑Ti Marras 25, 2025 10:07 am Missä noita on myynnissä ja mihin hintaan?
Videon kuvauksesta löytyy linkki sademetsään:
Using a tire gun mushroom plug repair kit to fix a puncture, this time showing internal views of the plugging process.
~~~~ Part Links ~~~~
As an Amazon Associate I earn from qualifying purchases.
🚗 Tire Gun Repair Kit ~ https://amzn.to/4ny7cBj
Disclaimer: TopTipMechanic is a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to www.amazon.com
NOTE: This kit is designed for tubeless tires and any repairs should only be carried out on the main treaded area of the tire and NOT on the shoulder or sidewall sections. This should only used as a temporary repair to get you to a tire shop to have the tire inspected and patched internally. This is not intended to be a long-term fix or a replacement for a professional tire repair. I am only demonstrating how to use the repair kit, I have nothing to do with its design or manufacture. WARNING: Use of this product could void tire warranty. Do NOT attempt any type of tire repair if any of the following conditions exist:
• The tire has less than 1.6mm tread depth
• The puncture is greater than 1/4 inch diameter (6mm)
• There is structural damage to tread, carcass, inner liner, or bead (including cracking, bubbling, ply separation, etc.)
• The puncture is on the shoulder or sidewall of the tire
• The tire has been inflated with any flammable gas
• The perforating object cannot be located
• The perforating object is not straight indicating the puncture path is not straight
• There is little resistance felt when inserting the repair
• There is evidence that the tire has been driven under-inflated
• There is evidence of possible structure/internal damage
Disclaimer:
Under no circumstances will TopTipMechanic be responsible or liable in any way for any content, including but not limited to, any errors or omissions in the content, or for any loss or damage of any kind incurred as a result of any content communicated in this video, whether by TopTipMechanic or a third party. In no event shall TopTipMechanic be liable for any special, indirect or consequential damages or any damages whatsoever resulting from loss of use, data or profits arising out of or in connection with the availability, use or performance of any information communicated in this video. Due to factors beyond the control of TopTipMechanic, it cannot guarantee against improper use or unauthorized modifications of this information. TopTipMechanic assumes no liability for property damage or injury incurred as a result of any of the information contained in this video. Use this information at your own risk. TopTipMechanic recommends safe practices when performing any do it yourself repairs and or with tools seen or implied in this video. Due to factors beyond the control of TopTipMechanic, no information contained in this video shall create any expressed or implied warranty or guarantee of any particular result. Any injury, damage, or loss that may result from improper use of these tools, equipment, or from the information contained in this video is the sole responsibility of the user and not TopTipMechanic.
XL250R
Pyörä: V-Strom
Viesti Kirjoittaja XL250R »
Kiitos!
