Garmin zumo 350 ja Mapsource Toimiiko?
pauli
- Pyörä: Transalp xl 600v
Mapsource ei tunnista garmin 350. 660 tunnisti kun vielä oli ehjä! Basecamp tunnistaa 350 kyllä, mutta kun on aina käyttänyt tuota mapsourcea niin basecamp tuntuu niin vaikeelta!
Re: Garmin zumo 350 ja Mapsource Toimiiko?
Samaan törmäsin 390:n kanssa kun sen laitoin aikoinaan. Kokeilin kolmella eri koneella jossa oli molemmat, piti luovuttaa ja opetella käyttämään Basecamppiä
Voihan se olla että jollain tempulla saakin, ei vaan viitsinyt alkaa enempää säätämään silloin.
Mitä tarkoittaa 'ettei tunnista'?
Kannattaa lukea tämä ajatuksella ja kokeilla uudelleen: https://forums.garmin.com/showthread.ph ... T&p=121993
Sama optio pitäisi löytyä noista.
https://www.juvander.me/ilpo
Winkula
- Pyörä: GL 1800 / F 800 GS / XT 600
Kokeileppa tätä
As the Zumo 340 or 350 LM is also the same problem with MapSource, Windows 7 and Garmin Zumo 390 If you connect the navigation system to the PC (XP operating system), you can without problems things from MapSource transmitted or received by the device. The Navi is immediately found by the program. however you Utilizes a PC with Windows 7 and do not want to renounce Garmin MapSource, then one is initially posed a problem. The PC recognizes the Navi, it also shows in the computer / workstation as a mobile device. But you start MapSource, it is not recognized. Base Camp recognizes the Navi on the other hand immediately.
The navigation system is recognized under Windows 7 as a mobile device and not as a USB drive with a small matter of adjustment, the problem can however fix: 1) Start the navigation, while it can not be the PC be connected 2) In the main menu click on "map" 3) In the window that opens, right down to "pace" button 4) It will open the trip computer. Here, press the center indicator with speed and direction and hold 5) If you have pushed long enough (10 seconds maximum), opens an English view. There is now even go down. Sometime displays the menu item "MTP Settings" - click 6) In the window that opens, set the mode to convert "Mass Storage Mode" and confirm 7) Go back to the main menu on the little arrow
The navigation system now to the PC -> It is recognized now also under Windows 7 in MapSource
Tuon ohjeen avulla sain omani pelittämään.
pauli
Ok, näyttäis onnistuvan!
